 Post subject: starter clicking
PostPosted: Thu Jun 02, 2011 9:53 am
Has anyone had an issue with the starter clicking when you try to start it? Mine will just click sometimes and then start right up.It has done it ever since i have had it. I have checked all the connections and the starter bolts are tight so i know its getting a good ground and voltage.I'm pretty sure i need a replacement since it is under warranty
 Post subject: Re: starter clicking
PostPosted: Sat Jun 04, 2011 6:06 am
Check the connections in the battery box too?
I dont know the specifics, but the previous owner had the starter replaced in my 2010.
PostPosted: Sun Jun 05, 2011 12:21 am
Sounds like a bad solonoid. If so, it will eventually quit working.
PostPosted: Sun Jun 05, 2011 6:08 am
Agreed on the eventually not working at all part, but my bet on the broken component was the opposite. The solenoid part is working and making the clicking when engaging the bendix. The starter motor is not spinning and what my money is on.
PostPosted: Mon Jun 06, 2011 9:40 pm
just had the same issue fixed by my dealer.
starter started intermittently clicking late last season, took it in at end of season, they said it was loose wire. tried firing it up to start this season, and click, click, click?
double checked all connections, and they were good.
took the boat back to the dealer and told them to check the starter this time!
sure enough, they confirmed solenoid was bad. so they replaced the entire starter.
now she fires right up, every time!
it is the starter, have them replace it! sounds like an issue with many boats?
2010 Axis A22
PostPosted: Tue Jun 07, 2011 12:56 pm
Thanks Darth. That was the info i was looking for.
PostPosted: Mon Jun 13, 2011 2:19 pm
changed out the starter works great now !
PostPosted: Thu Jun 16, 2011 7:47 pm
Good to hear...
I wish I would have figured it out sooner, as it would have saved me 6 hours driving time (X 2 trips) to get to the dealer the first time!
2010 Axis A22
