It is currently Mon Oct 26, 2026 10:25 am
 Post subject: Re: Pre Hi-flo pnp drain improvement - 3/4" to 1 1/8"
PostPosted: Fri Apr 29, 2016 1:42 pm
wtstapel wrote:
Spoke with Malibu. They told me I cannot replace the hard tank fittings on my 12. I wanted to talk with a rep before I pulled the fitting off.
If you just need to improve drain times you do not need to take off fittings. The inlet is the same size 3/4. The output of the pump is larger 1-1/8.
https://www.bakesonline.com/detail.aspx?ID=2924
PostPosted: Fri Apr 29, 2016 3:14 pm
My 12' has all the 1 1/8" hoses and tank fittings, etc. I also have the SS thru hill fittings. You might want to try pulling your tank fittings to see if you could swap them out. I wouldn't just go off of what a Malibu rep says.
