Axis Fresh Air Exhaust http://axiswakeboardboats.com/viewtopic.php?f=14&t=4813 |
Page 1 of 2 |
Author: | pcross9 [ Thu Jun 06, 2019 3:07 pm ] |
Post subject: | Axis Fresh Air Exhaust |
So last fall I purchased an Axis FAE, planned on installing this spring on my 2016 T-23. Because of concerns with factory warranty I decided to let the dealer install it. Figured it was about a 30 minute job, no big deal. The dealer just called and said they can’t install it on the boat while it’s in getting ‘summerised’ because it’s a very involved three or four hour job! 1. If I install it will it void my warranty on the engine? 2. Is this really a 3 to 4 hour job? Thanks Sent from my iPhone using Tapatalk |
Author: | Rmilbour [ Thu Jun 06, 2019 3:41 pm ] |
Post subject: | Re: Axis Fresh Air Exhaust |
I just installed FAE on my 2015 A20 about 3 weeks ago. I would imagine it would be a similar project. If you are in any way handy, you can do it. It’s not hard at all. Follow the directions and take the measurements it tells you to. A couple things I would recommend- 1- remove the swim platform. It’s really easy to do you’ll need someone to help you. It’s heavy for one person 2- don’t forget any of the washers! When you tighten the bolt or nut will easily dig into the metal of the bracket 3- don’t tighten the nylon washers down until you are 100% 4- be careful installing the adapter piece that replaces the flapper. Don’t strip the screws w a drill. Good luck! I’d guess you can do it w 3-4 beers and 2-3 hrs. Attachment: IMG_0037.jpg [ 316.29 KiB | Viewed 34365 times ] Sent from my iPhone using Tapatalk |
Author: | Clayne100 [ Thu Jun 06, 2019 5:39 pm ] |
Did you remove the factory muffler when install the FAE? Sent from my iPhone using Tapatalk |
Author: | Rmilbour [ Thu Jun 06, 2019 8:27 pm ] |
I didn’t. I asked the FAE guy and he said there have been lots done w out doing that and no reported issues. Sent from my iPhone using Tapatalk |
Author: | Clayne100 [ Thu Jun 06, 2019 9:53 pm ] |
Rmilbour wrote: I didn’t. I asked the FAE guy and he said there have been lots done w out doing that and no reported issues. Sent from my iPhone using Tapatalk Any sense if you mileage was affected? Sent from my iPhone using Tapatalk |
Author: | Rmilbour [ Thu Jun 06, 2019 10:18 pm ] |
I have noticed a slight decrease in mileage. Doesn’t affect our lake days. I can still make it on a tank for a full day of boarding and 6-10 adults in the boat. The noise reduction is fantastic. Sent from my iPhone using Tapatalk |
Author: | pcross9 [ Fri Jun 07, 2019 5:10 am ] |
Does installing it myself do anything to the factory warranty? I have 4 years left and don’t really want to lose coverage over the install. Sent from my iPhone using Tapatalk |
Author: | A22owner [ Fri Jun 07, 2019 6:26 am ] |
Rmilbour wrote: I didn’t. I asked the FAE guy and he said there have been lots done w out doing that and no reported issues. Sent from my iPhone using Tapatalk If you remove the factory muffler you will probably see a little performance increase. On the factory surf pipe option it is removed because of excessive back pressure. |
Author: | Rmilbour [ Fri Jun 07, 2019 7:51 am ] |
Do you know if there are any good videos on the muffler removal process? In regards to the warranty. I’m not sure if it would void anything. I would check with Axis. Sent from my iPhone using Tapatalk |
Author: | A22owner [ Fri Jun 07, 2019 8:57 am ] |
Rmilbour wrote: Do you know if there are any good videos on the muffler removal process? In regards to the warranty. I’m not sure if it would void anything. I would check with Axis. Sent from my iPhone using Tapatalk No videos that I'm aware of. |
Page 1 of 2 | All times are UTC - 6 hours |
