It is currently Fri Oct 30, 2026 1:10 pm
 Post subject: Re: What to order on 2018 Axis?
PostPosted: Mon Dec 11, 2017 8:29 pm
steveA20 wrote:
brandonT22 wrote:
I️ ordered an 2018 A24 and got it about month ago, came from 2015 t22
I️ got all the options except
Surf pipe
Ptm racks
Heaters
2nd tracking fin
Got sound pack 1
Standard trailer with alloy rims
Have you added tower speakers yet? If so, how was wiring the tower? I'm really bummed they stopped pre-wiring the tower with SP1.
I rewired mine and it's not bad at all.. originally I tried to use the factory wiring to pull new wires through and broke them so I just ended up pushing a new small wore through and using it to pull the larger wire through. The hard part was the hole where the tower bolted to the hull was not large enough so I had to drill it out.
PostPosted: Mon Dec 11, 2017 9:51 pm
Surf pipe
Ptm racks
Heaters
2nd tracking fin
Got sound pack 1
I’m putting 2 rev410s on the tower. I’m putting the ring kits on them right now and in next couple of days will put them up on the two. Going to use 12 gauge wiring. I’m going to start with just using gravity and hope that works then go from there maybe try fishtape.
What sub are you going to use? I️ was thinking of 15” kicker l7 under glovebox. Under the dash there isn’t much room at all.
PostPosted: Thu Dec 14, 2017 5:57 pm
brandonT22 wrote:
Surf pipe
Ptm racks
Heaters
2nd tracking fin
Got sound pack 1
Did u get the wires ran yet?
PostPosted: Mon Dec 18, 2017 10:36 pm
LOBAWavers wrote:
cbray4 wrote:
I like your list. Would it be okay if I PM'd you at some point with some more questions since you have recently gone through this whole deal?
But keep this thread going - I too am thinking about ordering a T22 or A22 and would like to hear everyones input!
If your still trying to decide between t22 and a22 my vote goes for t22. Bow space is nice on a22 but from what I have heard from friends is that you won’t get as much use out of it as you want. I think that the extra cab space makes the layout a lot more comfortable. When we go out people usually hang out In the cab but when people want to go on the bow there is still plenty of room.
2015 T22
PostPosted: Wed Dec 20, 2017 6:48 pm
r33pwrd wrote:
Surf pipe
Ptm racks
Heaters
2nd tracking fin
Got sound pack 1
I rewired mine and it's not bad at all.. originally I tried to use the factory wiring to pull new wires through and broke them so I just ended up pushing a new small wore through and using it to pull the larger wire through. The hard part was the hole where the tower bolted to the hull was not large enough so I had to drill it out.k
And why was this necessary , I have sp1 with pre wired tower, your scaring me for my eventual upgrade to tower speakers
