It is currently Fri Oct 30, 2026 1:36 pm
 Post subject: Re: Oil Change in A20... Help please.
PostPosted: Sun Nov 20, 2016 10:46 pm
I found a female to male barb at Home Depot that worked great. Posted a pic on the forum. It was for a 2015 a20 w 350. Unscrewed the cap on the oil line, Screwed the barb fitting onto the oil line, then attached the extractor pump line to the male connector and used a small clamp to secure it. Takes 10-15 min. Very easy. Tranny fluid is a breeze too. Maybe $40 in parts and a couple beers.
PostPosted: Sun Nov 27, 2016 7:22 am
He has someone to do it. LOL. He spoke to soon. It is crazy what dealers are charging to winterize... I may go in business. The dealer here literally hooks a sump pump to your boat through a fake a lake or transom flush rig. They turn your boat on and then turn their pump on and wait until they see the color of antifreeze coming out. They will blow your heater out after your motor has antifreeze by disconnecting to and from lines. For hard ballast tanks they pour a little antifreeze in through the vent lines. Never seen them use fogger or anything.
Gibby
2011 A22 Vandall
PostPosted: Thu Aug 10, 2017 3:48 pm
A Quick Video i put together on quickest way to change your oil in your Axis
[Youtube] https://www.youtube.com/watch?v=P6HJcVHhapw [/Youtube]
PostPosted: Thu Aug 10, 2017 6:39 pm
You might want to fill the new filter half way with fresh oil. Also, if you put a plastic bag around the old filter during removal it contains a lot of the spill.
