It is currently Fri Oct 30, 2026 10:18 am
 Post subject: Loose MTX speaker connections
PostPosted: Thu Sep 08, 2011 6:28 pm
I was adding a Bluetooth music gateway today to the AUX input and decided to tune the Stereo...Switched the amps to 1x: much better. Found the rear port speaker was disconnected. Drain lines rest on the speaker wire and it was loose. The other port rear speaker was sounding like it was blown. Removed and found it was also just a loose ground connection. In both cases just squeezed the connector with pliers and reattached.
